1992 Toyota 4Runner transfer case
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
SPANIC
I have a 92 4runner and the tranfercase has had a very slow leak and recently is leaking worse than normal especially after i went 4wheeling the other day. I have 5.29 gears and locker and auto transmission,v6 and 33 in tires and 6 inch lift. Is it a big problem?
thanks
Apr 23, 2009 at 10:00 AM
  • 31,937 POSTS
Hi there,
Any oil leak is a problem, if you let this go with out repairing it correctly you run the risk of running low on oil & destroying the transfer, get it repaired don't ignore it.
Mark (mhpautos)
Apr 23, 2009 at 4:44 PM
