HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
4Runner
Ignition
Timing
1992 Toyota 4Runner Timing
TYPHOMOMY
MEMBER
1992 TOYOTA 4RUNNER
6 CYL
4WD
MANUAL
250,000 MILES
What is the TDC for this vehicle and where are the timing marks. Also how much is the electronic manual for my vehicle.
Thursday, May 13th, 2010 AT 7:16 PM
MECHANIC
It means no.1 piston is at compression stroke/TDC and camshaft and crankshaft are line up to their markings and crankshaft pulley at TDC/O markings
For the manual go here:
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
SPONSORED LINKS
Thursday, May 13th, 2010 AT 7:46 PM
Please
login
or
register
to post a reply.
Related Ignition Timing Content
How To Set The Timing?
I Have A Rebuilt Toyota 22re Engine Fuel Injected. It Starts Fine, It Idles Fine, I Have The Timing Set At 5 Degrees For Tdc. The Thing Is...
Asked by
Anonymous
1 ANSWER
5 IMAGES
1987
TOYOTA 4RUNNER
1995 Toyota 4runner Erratic Ignition Timing
Bought The 4runner With A Spun Rod Bearing. Never Ran The Vehicle Before Rebuilding The Engine. After The Rebuild The Ignition Timing...
Asked by
davidfarrand
1995
TOYOTA 4RUNNER
1997 Toyota 4runner Timing Maybe?
Ok So I Went Mudding About A Week Ago And Hydrolocked My Engine. I Pulled The Plugs And Turned The Engine Over Manually To Get As Much Of...
Asked by
jmt2404
1997
TOYOTA 4RUNNER
1991 Toyota 4runner Timing And Fuel Issue On 3.0l V6
I Have Just Completed Rebuilding A 3vz Motor In A 1991 4runner, It Seem As It The Timing Is Not Advancing At Higher Rpm's. It Runs Good...
Asked by
liftedtoys
1 ANSWER
1991
TOYOTA 4RUNNER
1995 Toyota 4runner Timing
Ive Set The Timing 3 Times On The 4 Runner In Seconds It Kicks Right Ouy Out Of Place Im Lost. What Should I Do
Asked by
A11667722
1 ANSWER
1995
TOYOTA 4RUNNER
VIEW MORE
SPONSORED LINKS
Symptoms of Low Engine Power
Low Engine Power
Fix an Engine with Low Power!
Online car repair manuals
