1992 Toyota 4Runner Straight Fuel coming out exhaust
191,000 MILES • 6 CYL • 4WD • AUTOMATIC
KEVIN_AUNE
Recently replaced long block of V6 motor using original manifold and electronics.
Will start--runs rough and fuel comes directly out exhaust.
Need to know what all should be checked that could cause this.
Aug 3, 2010 at 6:10 AM
KHLOW2008
  • 41,812 POSTS
Hi Kevin_Aune,
Thank you for the donation.
Excessive fuel are mostly cause by bad injectors that are stuck in the open position.
You need to remove the injectors to test.
Aug 4, 2010 at 6:26 AM
