1991 Toyota 4Runner wont go
1991 TOYOTA 4RUNNER
89,000 MILES • 6 CYL • 4WD • AUTOMATIC
BABASJA
i just replace the transmission it reverse well but wen in drive it struggle and sounds like it is trying to move in a higher gear than first gear.(you know it goes 1 to 2 to 3 to 4 . it sounds like it is trying to move off in 3rd or 4th gear .
WHAT COULD BE THE PROBLEM
1991 TOYOTA 4RUNNER 3VZ INGINE SR5 ,V6 ,4WD
Dec 22, 2007 at 3:50 AM
You need to check/test the 3-speed sensors-1 behind the speedometer, the other is on the left rear of the transmission, and the other is on top of the rear differential.
Ans also the throttle position sensor.
Dec 22, 2007 at 4:54 AM
