1991 Toyota 4Runner water pump or therostat?
153,000 MILES • 6 CYL • 4WD • AUTOMATIC
MRCE
only drips at this time and only when not running. no noise. looks like it is coming below the therostat, but hard to tell if not water pump. temp seem to be ok when driven. possible that bad seal on therostat???
Sep 22, 2008 at 4:48 PM
  • 75,988 POSTS
If its coming from the thermostat
Better change it now whether its leaking running or not-sooner or later its gonna bust wide open lose the coolant and there goes the headgasket head/block and a big repair bill to fix it
Replace the thermostat and the thermostat housing gasket-make sure you position the jiggle valve in place with the mark.
Apr 29, 2020 at 3:35 AM
