1991 Toyota 4Runner Starter replacement
195,000 MILES • 6 CYL • 4WD • AUTOMATIC
ARTHUR F. KIRWAN
Need to replace starter - no matter how many time I try - cannot access bolts to remove. Can't see from top, bottom and from side can see top bolt, not bottom. Can't get access to turn wrench if I could see. Manual says lift auto and place on stands - that provides no additional access. Manafold on top prevents access, front end prevents underneath access, brake lines prevent side access. How does one change this starter. I have changed starters on other vehicles and this is infuriating. Please provide the insiders secret.
Thanks Art K
Nov 5, 2008 at 5:07 AM
BURNY
Remove passenger side front tire and access it that way. I still have original starter shell in my 91 4runner and have replaced the contact twice in it. $10 and about 45 minutes time.
Jan 31, 2009 at 12:07 PM
