1991 Toyota 4Runner Need help my daughters 4runner having i
MARSHA33
Electrical problem
1991 Toyota 4Runner 6 cyl Four Wheel Drive Automatic
We have replaced the battery and the altnator,the battery cables and the toyota still having trouble, it will be fine when she starts it up in the morning and when she stops some where and turns it off it wont start for a while,what can cause this? Help
Jul 13, 2009 at 5:11 AM
  • 75,988 POSTS
Next time it won't start don't wait do below to determine if its fuel or spark problem.
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Jul 13, 2009 at 5:47 AM
