1990 Toyota 4Runner Sunroof
1990 TOYOTA 4RUNNER
215,000 MILES • 6 CYL • 4WD • MANUAL
MKCURRAN
I am having a problem with my sunroof.. It will go back but will not close. It sounds as if the motor is working fine and then it makes a grinding noise.
i'm not sure if there is a cable disconnected?
thanks
Jun 14, 2008 at 5:03 PM
  • 31,937 POSTS
Hi there,
The regulator mechanism has failed you will have to remove the roof lining to inspect.
mark (mhpautos)
Jun 14, 2008 at 8:44 PM
