1990 Toyota 4Runner engine idle
173,350 MILES • 4 CYL • 2WD • AUTOMATIC
DIEHARDHIPPY
I Have a 1990 Toyota 4 runner that runs really good just replaced spark plugs on it they where fouled out it has been rough to start when I changed the plugs this hard starting went away. Now I start the car with no-problems my problem is that after the car has been running for like 5 to 7 mins after it starts to get warm the engine idle jumps from 12oo rpms to to 23oo rpms and back to 1200 and it keeps doing that untill I put the car in gear then it runs fine but if I put the car in nuetral or park idle gets irregular again any suggestions?
Nov 17, 2009 at 3:54 AM
  • 75,988 POSTS
Clean out the idle air control valve and test the throttle position sensor and airflow meter to include a fuel pressure check.
Nov 17, 2009 at 8:05 AM
