Continuously goes To Floor
30,000 MILES • 4 CYL • 4WD • MANUAL
SILOMONKEY
  • 6 POSTS
I replaced Front Brake Pads, On 4 Runner, Fiill The reservoir With Fluid Pedal Continuously goes To Floor , I've Bled Brakes Several Times to No Avail.
Apr 9, 2009 at 4:58 PM
  • 31,937 POSTS
Hi
If there are no external leaks, i would be thinking that the master cylinder is by-passing fluid internally, often this is the case when brakes are bleed with an old cylinder as the piston travels down the bore further than normal it can damage the seal on deposits that build up on the bottom of the cylinder.
Mark (mhpautos)
Apr 12, 2021 at 2:59 AM
If there's no leaks anywhere I suggest you replace the brake master cylinder it has an internal leak
