1989 Toyota 4Runner replace front crankshaft oil seal
167,000 MILES • 6 CYL • 4WD • AUTOMATIC
BEACHCOMBER4YOU
  • 23 POSTS
how to you remove the timing gear sprocket from the crankshaft to replace the oil seal .
Aug 31, 2010 at 9:52 AM
MADMIKE1735
  • 951 POSTS
most of the time, they should slide off... in your case, your going to need to convince it a little... spray some pb blaster on it, let it soak... your going to need 2 flat head screw drivers, or small prybars... grab behind the pulley, and work it off the crankshaft... place rags behind the screw drivers to prevent damage to block... hope this helps ya...
Aug 31, 2010 at 9:59 AM
BEACHCOMBER4YOU
  • 23 POSTS
Thank you very much for your suggestion , I have tried all of this allready. Do you know if taking a torch to heat it up real good would damage anythinhg? If not I thi
https://images.2carpros.com/forum/automotive_pictures/530367_P1010295_2.jpg
nk that would work. M.GenzanoIII
Aug 31, 2010 at 11:53 AM
MADMIKE1735
  • 951 POSTS
i wouldnt reccomend using a torch unless u have tried every other possible way... and if u do end up heating the pulley to get it off, throw it out... once super heated, they are no good... try using a small 2 arm puller... there may be just enough room behind the pulley to grab onto, and see if u can pull it off the crank that way....if the puller can grab it, but it still wont come off, once u get a bunch of load on the puller screw, hit it with a hammer to "shock" it... this sometimes will loosen up a stubborn pulley...
Aug 31, 2010 at 12:04 PM
BEACHCOMBER4YOU
  • 23 POSTS
Thank you very much for all your help, And GOD bless you in JESUS name a-men!!!
M. Genzano III
Sep 1, 2010 at 2:36 AM
