1989 Toyota 4Runner engine noise
JDH83FAN
  • 1989 TOYOTA 4RUNNER
  • 4 CYL
  • 4WD
  • MANUAL
  • 215,000 MILES
When is start my 4runner it makes a loud knocking sound from the start.I cant go over 20 mph now and it knocks louder if I try to drive it then it over heats and white smoke comes out and the water starts to boil. The knockin sound never quits.I took it to a mechanic and they said the crankshaft went out. Can I just replace that or do I have to replace the whole engine or wat. Please help me!
Tuesday, August 26th, 2008 AT 7:50 PM
  • 31,937 POSTS
Hi there,
it sound as if you have a few problems to deal with, I would be having a compression test, oil pressure test and head check done, I think you will better of re building the engine if you have been running with low oil pressure as the bearing knock is destroying the engine, and the over heating and white smoke could well be a head gasket or cracked head.
Mark (mhpautos)
Tuesday, August 26th, 2008 AT 11:11 PM
JDH83FAN
How much do you think it would cost to rebuild the engine on my 4runner? And does anything else need to be replaced?
Wednesday, August 27th, 2008 AT 9:46 PM
  • 31,937 POSTS
Hi there,
This is a very hard question to answer with out viewing the engine dismantled. If you are working to a budget you may be able to pick up a re-co and have that installed rather than doing yours, this will be quicker and often cheaper as well. As for extras. Do the radiator all the hoses, thermostat, have the starter checked
Mark (mhpautos)
Wednesday, August 27th, 2008 AT 9:53 PM
JDH83FAN
Thank you for the advice I couldnt find anyone else to help me.
Thursday, August 28th, 2008 AT 9:51 PM
