1988 Toyota 4Runner dosent get enough fuel
1988 TOYOTA 4RUNNER
185,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARY DECKER
88 4runner 4wd v6 truck runs but wont rev over 1200 rpm im a technician and cant solve the prob ive changed fuel pump strainer and the filter the pressure is good its not the regulator or the tps or the cat or the mass air or the injector wiring or the body and engine grounds ive checked these items but if i hold the throttle down and pour a little gas down a vac line it revs up so its not the dist could it be the computer witch i doubt because if i disconnect the mass air it cuts off like it should. if i hold the throttle down it just surges and backfires
i dont know what else to do please help
Oct 23, 2010 at 2:31 PM
Try determining the actual fuel pressure with and w/o vacuum on the regulator and check the EGR and PCV valves-to include vacuum leaks-Did you do a backpressure test to rule out the Cat?
Oct 24, 2010 at 6:03 AM
