1987 Toyota 4Runner Starting
1987 TOYOTA 4RUNNER
ROB2008
  • 258 POSTS
Engine Performance problem
1987 Toyota 4Runner 4 cyl Four Wheel Drive Manual Alot miles
My problem is I go to start my truck and usually it takes a couple of minutes for it to run . ,but when it does it runs great ... could it be the cold start valve or what ?? I checked they fuel injection pressure regulator and it seems to be fine .. could you give me any ideas of what it might be ??
Apr 25, 2008 at 9:50 AM
Check the fuel pressure with a fuel pressure gauge/the coolant temperature sensor to include the cold start valve.
Apr 25, 2008 at 10:01 AM
ROB2008
  • 258 POSTS
Ok , thank you for the suggestion ,
-Rob
Apr 25, 2008 at 10:25 AM
