1986 Toyota 4Runner Taking the bolt off the crankshaft pull
1986 TOYOTA 4RUNNER
240,000 MILES • 4 CYL • 4WD • MANUAL
RYANK1982
on the crankshaft pulley bolt or nut does it have reverse threads or normal threads?
Apr 19, 2008 at 2:46 PM
ROB2008
  • CAR REPAIR CONTRIBUTOR
  • 258 POSTS
I also have A Toyota about the same year and yes it has normal treads ( righty tighy lefty loosey ) I had a problem with the crankshaft bolt .. If I remember right you need a 17mm or 19mm socket .. what I did was put it in gear and I had someone in the truck holding the brakes . I took a five pound hammer and put a socket and long ratchet on there and tapped it loose . Hope this helps !
-Rob
Apr 22, 2008 at 12:13 AM
