Once throttle gets to a certian spot it starts to hesitate and gets worse as throttle is pressed a bit further, then will accelerate if continued to press throttle down - then as throttle is lifted there is a point where the condition stops and runs better. So if you press down the throttle around this point it actually hesitates more - let off and the acceleration increases. Any thoughts?
SPONSORED LINKS
Monday, April 14th, 2008 AT 10:02 PM
