I have a 1985 toyota 4runner efi. When I turn the key, it will start and then die. If you give it a little bit of throttle it will start run funny and then die. I replaced mass air flow sensor, all temp sensors, cold start injector, ignitor coil, plugs and wires, cap and rotor. What is wrong with it?
SPONSORED LINKS
Sunday, August 2nd, 2009 AT 11:22 PM
