1985 Toyota 4Runner
81,500 MILES • 4 CYL • 4WD • MANUAL
WINTERS.R
my 85 4runner will start up right away but it has no power, it idles around 400 rpm. when i push on the gas the rpms rise slowly. i gave it a tune up and replaced o2 sensor,mass air meter, throttle posion sensor and checked to see if there was a vacuum leak. satill runs the same. what could the problem be?
Feb 13, 2008 at 1:56 PM
  • 75,988 POSTS
Check for an excessive backpressure in the exhaust system to rule out the catalytic converter and also the fuel pressure
Feb 14, 2008 at 9:45 AM
