1984 Toyota 4Runner charging
MDEATER
Electrical problem
1984 Toyota 4Runner 4 cyl Four Wheel Drive Manual many miles
MY 4runner won't charge. After turning on and off a few times the battery needs to get jumped. I have just installed a new battery and alternator. When the vehicle is running the voltage across the battery is 12.63. Doesn't ever seem to charge.
May 11, 2009 at 1:32 PM
  • 75,988 POSTS
Ground the field on the D hole on the back and see if it goes higher than that-if so regulator is bad
May 11, 2009 at 1:36 PM
