Toyota 141 engine 1nz?
268,000 MILES • 1.6L • AUTOMATIC
HSNDSOME
  • 33 POSTS
P0500 an C1541 code, speed km guage on dash is not working. Check engine an power steering warning light is on.
Sep 28, 2026 at 10:31 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Start by confirming the vehicle's market, chassis and engine identification, and whether ABS is actually fitted. A scan tool reporting an incompatible ABS system does not by itself prove that the vehicle has no ABS. Use the matching Toyota wiring information to establish where this version obtains its vehicle-speed signal. Have a technician record the engine and steering fault codes and compare the speed information available to the relevant modules. With the vehicle stationary and switched off, inspect accessible speed-signal wiring and connectors for looseness, corrosion or damage. Any moving-vehicle test should be controlled by the technician; do not watch a scanner while driving or road-test a vehicle with abnormal steering assistance. If the confirmed speed sensor produces no signal, test its circuit and the applicable supply or ground before condemning it. If a valid signal leaves the source but fails to reach another module, trace that path using the wiring diagram. Repair the demonstrated fault, then verify the speedometer, steering assistance and codes. The missing speed information is a useful diagnostic lead. It gives the technician a focused starting point without assuming that several expensive components have failed.
Guidance references and applicability
HELLA technical guidance on transmission rotational-speed sensor circuits: https://www.hella.com/techworld/ae/technical/sensors-and-actuators/transmission-range-sensor-circuit/ The English page is titled 'Transmission range sensor circuit' but discusses Hall and inductive rotational-speed sensing. It supports checking sensor type, wiring, supply and signal using a circuit diagram. Its example measurements are not Toyota specifications and are not prescribed here. Toyota information for the exact market and chassis is required to establish the actual speed-signal path and code definitions.
Read the replies · Discussion summary and reported outcome
  • 55,746 POSTS
P0500 means the ECM is not receiving a valid vehicle-speed signal. C1541 is an electric power-steering code related to missing/abnormal vehicle-speed information. That explains why the check-engine light and power-steering warning light can appear at the same time.
Start by connecting a scan tool capable of reading live data and look at Vehicle Speed while driving slowly. Also check the individual ABS wheel-speed sensor readings if the scanner supports ABS data. Let me know what you find. This might be two separate issues.
Sep 28, 2026 at 5:30 PM
HSNDSOME
  • 33 POSTS
On the scan tool went into the abs section an saying not compatible, car has no abs module box.Will xheck thd speed sensor on the transmission.
Sep 28, 2026 at 6:06 PM
  • 55,746 POSTS
Yep, that would be my next step as well. Let me know if you need to know the location.
Sep 28, 2026 at 6:52 PM
Discussion summary
The owner reported an inoperative speedometer, engine and power-steering warning lights, and codes P0500 and C1541. A contributor suggested examining vehicle-speed data and, where applicable, ABS wheel-speed data. The owner reported that the scan tool could not access ABS and believed the car had no ABS module, then planned to check the transmission speed sensor.
Reported outcome: No sensor test result, diagnosed fault or successful repair was reported.
The title identifies a 1NZ engine while the vehicle fields list 1.6 litres; the exact configuration needs confirmation. ABS equipment, scanner compatibility and the meaning of C1541 for this version have not been independently verified. A shared speed-signal problem is a diagnostic possibility, not a confirmed cause.
Read the original discussion
