would like to Tow my truck behind my RV
350,000 MILES • V8 • 2WD • AUTOMATIC
JOEBLUEYES
I have the truck listed above it is a C1500. I want to tow it behind my RV. I am having trouble finding a tow hitch to connect to the truck and I need to know if there is a way to tow with all four wheels down without having to disconnect the driveline?
Thank you
Oct 30, 2016 at 1:33 AM
HMAC300
  • 48,601 POSTS
you need to put a tow dolly under rear wheels. Uhaul has them to rent or look online to find them.
Oct 30, 2016 at 8:44 AM
JOEBLUEYES
HMAC300, Thank you for your reply, I realize i can tow dolly it from the rear, i want to tow it with all four wheels on the ground. any suggestions?
Oct 30, 2016 at 9:07 AM
HMAC300
  • 48,601 POSTS
the only way is to remove driveshaft and you will need to plug transmission where shaft went, other wise it will leak fluid.
Oct 30, 2016 at 9:57 AM
