Tow haul light comes on as soon transmission is shifted into gear
273,000 MILES • V8 • 2WD • AUTOMATIC
LYNP639
  • 10 POSTS
The tow haul light comes on as soon as I put the truck into first or reverse to start driving. In most cases it is also engaged, cause I can feel and hear it.
Jun 21, 2020 at 8:41 PM
Good morning,
Are there any codes in the system for the transmission?
Does it shift well while driving?
Jun 21, 2020 at 9:27 PM
LYNP639
  • 10 POSTS
Yes, if overdrive is not actually engaged (even tho light is on). If it's actually in overdrive, it doesn't want to work up thru the gears to accelerate.
Jun 22, 2020 at 8:09 AM
Okay, can you check for any codes?
There is a fault somewhere.
Jun 22, 2020 at 8:14 AM
LYNP639
  • 10 POSTS
I am not a mechanic, justt the owner. So no equip to test. Guess I'll have to take it in and leave it running next time it does this, so they can check it for codes while the light is on?
Jun 22, 2020 at 9:20 AM
A parts store will read them for free.
Once I get the codes, I can narrow the area of failure down for you.
Jun 22, 2020 at 9:22 AM
LYNP639
  • 10 POSTS
Thank you. I will take it out at lunch tomorrow and if it's doing it, get a store to read it for me. I've had them change batteries, and headlamps but didn't know they'd check for codes. Thanks for that tip!
Jun 22, 2020 at 1:27 PM
You are welcome.
Keep us updated with the results.
Jun 22, 2020 at 9:30 PM
  • 55,649 POSTS
Here is a guide to yelp you get the codes. but it sounds like the tow/haul button/switch is bad have you try cycling the switch?
Jun 23, 2020 at 4:56 AM
LYNP639
  • 10 POSTS
Thank you Ken. I have ordered a code reader. Had no idea I could do it myself! Very helpful article, and I appreciated the link to the codes in the article so I didn't have to buy a reader that tells you their description. Will be back in touch in a few days.
Also, if you will tell me how to "cycle the tow haul switch," I will try that too.
Jun 25, 2020 at 7:22 AM
  • 55,649 POSTS
Good work, cycle the switch mean to push it on and off many times to see if there is a change.
Jun 26, 2020 at 4:00 AM
When you tow heavy loads, it is recommended to turn it on. it disables the clutch converter in the torque converter to put less pressure on the transmission. Otherwise, you could damage the clutches. Those clutches are the least amount in any clutch pack and can easily be damaged if they are over worked by the heavy load.
Jun 26, 2020 at 4:04 AM
LYNP639
  • 10 POSTS
I've gotten the code reader. Used it this morning. No codes, even though tow haul light came on after cranking. Is it possible the tow haul switch wire is going bad? I saw some YouTube videos about it breaking after flexing so much during use.
Jun 29, 2020 at 10:18 AM
Okay, what is the brand code reader you got?
Some of them will not read anything but engine codes. They will not read any other system.
A quick test you can do is this. Run it up to 55 MPH and with your foot on the gas, let the other one touch the brake pedal and see if the transmission downshift.
If it does, then it was in overdrive. If it does not downshift, it will not change at all.
Jun 29, 2020 at 10:26 AM
LYNP639
  • 10 POSTS
I bought an Actron CP9125 OBD II PocketScan.
Jun 29, 2020 at 9:28 PM
Okay, thanks. That just reads the engine system. It will not read ABS or any other module.
Did you do the test I suggested with driving?
Jun 29, 2020 at 9:51 PM
LYNP639
  • 10 POSTS
Will do that later today.
Jun 29, 2020 at 10:32 PM
Okay, keep me updated with the results.
Jun 29, 2020 at 10:38 PM
LYNP639
  • 10 POSTS
Did the driving test you suggested several times. It did not downshift, unless I really pressed down on the brake. Also, it hasn't gone straight into tow haul mode after cranking and shifting into gear, in several weeks. It has been very warm in the mornings, like mid high 70's, so I wonder if air temperature makes a difference?
Jul 23, 2020 at 8:37 PM
Are there any codes set?
Jul 23, 2020 at 8:41 PM
LYNP639
  • 10 POSTS
Will check when I leave work this afternoon.
Jul 23, 2020 at 10:03 PM
Sounds like a plan.
Jul 23, 2020 at 10:14 PM
