Torx screw removal?
219,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
LEO END
I'm trying to change the head gasket on the car but the torx screw that's holding the engine block what budge every time I try to unscrew them it's eating the screw instead of unscrew it.
Dec 24, 2022 at 5:43 AM
  • 110,248 POSTS
Although a torx will fit, the bolt head requires a 10 mm bi-hexagon wrench. It has more blades than a torx and will prevent it from stripping the bolt.
If you have a pic of what is happening, upload it for me to see. Hopefully, I'll be able to provide suggestions
Let me know if you have questions.
Dec 24, 2022 at 10:20 AM
