Torque Specs Valve cover gasket replacement
85,000 MILES
ACE1966
I am trying to replace the valve cover gasket on my 2007 pontiac wave and I need to get the torque specs on the bolts so it doesnt leak again or break as the cover is plastic.
Thanks!
Adam
Apr 21, 2013 at 12:40 PM
  • 75,988 POSTS
This guide can help walk you through the repair
https://www.2carpros.com/articles/replace-valve-cover-gasket
You should tighten the valve cover bolts to - 89 in lbs
Apr 21, 2013 at 1:06 PM
