Torque specs for upper and lower intake manifold needed
161,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
GAVIN JAMES
As well as the fuel rail and the EGR valve and I need them in inch lbs please.
Aug 12, 2021 at 10:59 AM
STEVE W.
  • 15,409 POSTS
Lower intake is 89 inch pounds in two stages 40 - 89 pattern in first image.
Upper is 2 stages as well, 89 inch pounds then 45 degrees pattern in second image.
Rail and injector bolts are 89 inch pounds.
EGR tube fittings are 30 FT lbs.
Aug 12, 2021 at 11:41 AM
