HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Hyundai
Sonata
Engine
Cylinder Head
Valve Cover
Gasket
Replace/Remove
SPONSORED LINKS
Torque specs for valve cover gasket
AXE12
MEMBER
2017 HYUNDAI SONATA
2.0L
4 CYL
TURBO
2WD
AUTOMATIC
96,000 MILES
Torque specs for valve cover gasket replacement needed and order for adjustment the bolts
Thursday, December 19th, 2024 AT 6:23 PM
MECHTRIX
MECHANIC
9.8 NM is good I bit on the tight side but good
SPONSORED LINKS
Thursday, December 19th, 2024 AT 11:08 PM
MECHTRIX
MECHANIC
9.8 nm Or about 7.25 ft p. 10 nm is 7.37 ft p that's what I do them at. Never had any issues. Good luck
Thursday, December 19th, 2024 AT 11:26 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Valve Cover Gasket Replace/Remove Content
2000 Hyundai Sonata I Need Help!!
2000 Hyundai Sonata Automatic My Car Is Now Dead And Won't Start. At First It Was Just Sputtering Really Bad (misfiring I Assume)....
Asked by
ajsmomma06
2000
HYUNDAI SONATA
2000 Hyundai Sonata Mass Air Flow Sensor
I Need A Mass Air Flow Sensor, Is It Best To Buy A New One Or Would A Rebuilt Do The Job As Well? Also, I've Been Shopping Around, I...
Asked by
refinedwoman
2000
HYUNDAI SONATA
How To Set Timing Of Timing Belt After Rebuilding...
We Have Set The Cam Timing And Are At The Point Of Setting The Timing Belt Timing. Would Like Process And Diagram Of Marks.
Asked by
PTPT
3 IMAGES
2003
HYUNDAI SONATA
2003 Hyundai Sonata Timming Belt Broke
While Driving My Timming Belt Broke Is My Motor Still Good Or Do I Need A New Engine
Asked by
jamie101
1 ANSWER
2003
HYUNDAI SONATA
Engine Swap
Will The Engine From A 1990 Eagle Talon Fit Into A 1992 Sonata Gl? The Talon Is A Standard And The Sonata Automatic. If So What Kind Of...
Asked by
Garn9
1992
HYUNDAI SONATA
VIEW MORE
SPONSORED LINKS
Engine Oil Leak
Coolant Leak Symptoms
Service Throttle Body Toyota Highlander V6
Online car repair manuals
