Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Echo
Drivetrain
Transmission
Pan
Replace/Remove
Torque specs for transmission pan bolts
2000 TOYOTA ECHO
130,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
MUSHHUSKIES
MEMBER
I am replacing the transmission fluid and filter. I would like to know what the transmission pan bolt specs are? Thank you.
Oct 28, 2019 at 9:30 AM
Experienced Mechanic
Good evening,
The torque value is attached for the pan.
Image (Click to enlarge)
Oct 28, 2019 at 9:34 AM
MUSHHUSKIES
MEMBER
Roy, thank you sir!
Oct 28, 2019 at 9:47 AM
You are welcome.
Always glad to help.
Oct 28, 2019 at 9:50 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
