torque specs for the camshaft bearing caps
155,000 MILES
PEDROK
replaced rocker arm.
Mar 23, 2020 at 1:58 AM
Good morning,
I attached all the camshaft torque specs for you below.
The spec is in inch pounds and nm.
89 inch pounds is the spec you need.
Mar 23, 2020 at 2:05 AM
I attached all the engine specs but the Camshaft Bearing Caps are 10 Nm or 89 In Lbs.
Let me know if you need more of these. Thanks
Mar 23, 2020 at 2:32 AM
