torque specs for rear and front suspension?
128,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
RCKUDO
Just installed rear shocks and ordered upper and lower control arms due to rusted out old ones (had holes 4 - 6 inches long on lowers and at the shock mounts). Looking for a diagram or list of all torque specs. Will also be changing both stabilizer bar end links. Will be tackling the front as soon as I'm done with the rear, so a diagram or list of the font torque specs would be much welcomed.
Thanks so much, Bob
Aug 20, 2022 at 1:28 AM
  • 55,851 POSTS
Hi Bob,
Here is the torque spec for the front and rear suspension parts you have requested. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers, Ken
Aug 20, 2022 at 8:57 AM
SQM
  • 6,383 POSTS
See attached for both front and rear suspension diagrams with all the torque specifications.
Let me know if you need any other information.
Aug 20, 2022 at 8:58 AM
RCKUDO
Thank you both. That is what i wanted. Kudos to you both.
Aug 20, 2022 at 9:09 AM
SQM
  • 6,383 POSTS
You are welcome.
Thank you for using 2CarPros!
Aug 20, 2022 at 9:11 AM
JUAN PABLO APESTEGUY
  • 15 POSTS
Hi all! I am changing the suspension of navara d23 2024 for OME arb kit. This torque is ok for my model? Thanks in advance
Aug 6, 2025 at 7:50 AM
  • 55,851 POSTS
I would not think so, this post is for a 2012, to get the information you need I would start a new thread. Please post your new question here, you must be logged in.
Cheers, Ken
Aug 7, 2025 at 10:59 AM
  • 15 POSTS
Thanks Ken, i did it!
Aug 8, 2025 at 12:15 AM
  • 55,851 POSTS
Nice work :)
Aug 8, 2025 at 4:17 AM
