Torque specs for lower intake
178,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JASON EKLUND
Need torque specs for lower and upper intake and valve covers.
Nov 22, 2018 at 8:51 AM
  • 110,248 POSTS
Here are the specs. Picture 1 shows tightening sequence.
Lower Intake manifold
Using new lower intake manifold and thermostat housing gaskets, install the lower intake manifold and the 10 bolts.
Tighten in the sequence shown to .................... 10 Nm (89 lb-in).
_____________________
Don't know if you need it, but here is the info for the upper intake. Picture 2 shows sequence. Note that once they are torqued to spec, they need an additional 45 degrees turn.
Upper Intake Manifold
Using a new gasket, install the upper intake manifold and the 7 bolts.
Tighten in the sequence shown in 2 stages.
Stage 1: Tighten to .................... 10 Nm (89 lb-in).
Stage 2: Tighten .................... an additional 45 degrees.
Let me know if this is what you needed. If you have other questions, let me know.
Nov 22, 2018 at 1:22 PM
