Torque specs for intake manifold
170,000 MILES
MIKERIOS
I am replacing the intake manifold gasket on a 2007 Toyota Corolla. The charts seem to say that the bolts need to be tightened to torques between 80-110 foot-pounds (which seems like a *lot*!). But when I took the bolts off, it only took about 20 fp to remove them. How do I find out for sure what the torque I need for these bolts are? (The bolts are class 8 and class 10 bolts).
Apr 23, 2013 at 4:43 AM
WRENCHTECH
  • 20,760 POSTS
Install the intake manifold and throttle body with the 2 brackets, 4 bolts and 2 nuts.
Torque 30 Nm (306 kgf-cm, 22 ft. lbs.) 10nm/7th lb
Apr 23, 2013 at 5:03 AM
MIKERIOS
Thanks-- that seemed to work just right!
Apr 23, 2013 at 5:19 AM
