Torque specs for inner tie rod end and outer tie rod end jam nut
94,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JASON TRAVIS LAY
Replacing my inner tie rod ends and wanted the torque spec for the tie rod end itself and the outer tie rod end jam nut.
Nov 5, 2017 at 3:41 AM
  • 31,937 POSTS
you do the inner up with loktite on thread do up tight with correct tube socket 85 Nm and bend locking tab to secure, outer tie rod is much the same, do not use thread sealant, do up tight with spanner to 50 Nm and align split pin install split pin and bend over, always use new split pins, you will require a tow in alignment check as well. Tie Rod Nut 36 ft (49)
Nov 6, 2017 at 6:34 AM
