Torque specs for a lower ball joint needed
165,000 MILES • 2.0L • 4 CYL • 4WD • MANUAL
YOI55
I am looking for the torque specs for a castle nut on a front lower ball joint. I can find the specs for the two that bolt to the knuckle, but not for the one that bolts to the lower control arm.
Mar 16, 2022 at 3:46 AM
  • 110,248 POSTS
For some reason, my manual doesn't provide those specifications either. However, if you tighten it to approximately 90 ft/lbs and use a castle nut with a cotter pin, it should be fine. The cotter pin will prevent it from coming loose.
Let me know if that helps or if you have other questions.
Mar 16, 2022 at 9:39 AM
DONATING DAVER
I'm wondering as well. I applied anti seize to the bolts, so I would like to know the lubricated torque specs.
Jul 12, 2023 at 11:07 AM
  • 110,248 POSTS
Yes, that would still be the same. The anti-seize will just help prevent corrosion. The torque is the same.
Jul 13, 2023 at 4:36 AM
DONATING DAVER
According to what I have been reading, anti-seize does change the torsion-tension relationship of a fastener system, torque settings need to be recalculated. The Fastenal people say that even the oil from one's hands after eating potato chips will have an effect upon torque specs, so I am thinking that anti-seize will also.
Jul 13, 2023 at 6:19 PM
  • 110,248 POSTS
I never heard of that. Not saying it isn't possible, but a given ft/lb doesn't change. I haven't ever seen anything related to this in any manual or in 30+ years of working on vehicles.
Also, if you have a castle nut, I suspect there is a cotter pin that pushes through the top of the nut. That cotter pin prevents the nut from turning.
Jul 14, 2023 at 1:02 PM
