What are the Torque Specs and Tightening sequence for the Fuel Injection Plenum?
169,554 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
HARRY8026
  • 5 POSTS
Need torque specs and sequence for the Fuel Injection Plenum, replacing fuel injectors and gasket.
May 4, 2023 at 4:25 AM
  • 110,248 POSTS
I attached the torque specs and sequence for the intake manifold. Is that what you need or was there anything other?
Take a look at the pics and let me know if they help or if you have other questions.
May 4, 2023 at 12:42 PM
HARRY8026
  • 5 POSTS
This is the part that needs torque and tightening specs on, and the part on top. Here are some photos, thank you. This part which I think is called a Fuel Injection Plenum that bolts to the top of engine and the little part that bolts on top of this.
May 4, 2023 at 9:01 PM
HARRY8026
  • 5 POSTS
here are more photos.
May 4, 2023 at 9:08 PM
  • 110,248 POSTS
Take a look at the pics below. I attached the installation directions for the two components you mentioned. Let me know if that is what you needed.
May 5, 2023 at 3:11 PM
HARRY8026
  • 5 POSTS
Thank you so much, this is what I needed.
May 5, 2023 at 9:07 PM
  • 110,248 POSTS
You are very welcome. I'm glad it helped. Let me know if there is anything I can do to help.
Also, feel free to return anytime in the future. You are always welcome.
May 6, 2023 at 12:04 PM
