Engine and Transmission Mount Torque Specs?
140,000 MILES • 1.8L • AUTOMATIC
MECH87
Torque spec for upper, lower and motor mounts/ trans mount needed. Thank you.
Jun 27, 2026 at 10:10 AM
  • 55,721 POSTS
Hello, here are the torque specs needed
Upper/right engine mount Fastener Torque
Ground strap/ground line bolt 8–10 ft-lbs
Center mount nut 47–62 ft-lbs
Mount-to-body / mount bracket bolts and nuts 36–47 ft-lbs
Transmission mount / transaxle mount Fastener Torque
Mount-to-body bolts/nuts 36–47 ft-lbs
Main transaxle mount/bracket bolts 65–80 ft-lbs
Lower mount / roll stopper / torque strut Fastener Torque
Lower roll stopper-to-subframe bolts 36–47 ft-lbs
Roll stopper/bracket-to-engine or transaxle main bolt 80–94 ft-lbs
Engine mounting support bracket Fastener Torque
Support bracket bolts 47–62 ft-lbs
Other mount bracket bolts shown in the service diagram 36–47 ft-lbs
Let me know if you need anything else.
Jun 27, 2026 at 11:40 AM
