inner tie rods torque specs
99,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
YUNGDRAB
Hey, I'm replacing my Inner tie rods. I have a manual and everything that lists almost every torque spec except the inner tie rods. Please help me out.
May 11, 2019 at 7:43 AM
Hi Yungdrab,
Looks like you have a couple options. There is a TSB that shows the new design part. If you are using the old one with a pin to hold it in place you have a lower torque spec. If the newer design, then it is higher.
Let me know if you need anything else. Thanks
May 12, 2019 at 8:17 AM
