Cylinder head bolts torque specs needed
120,000 MILES • 3.4L • 6 CYL
HAROLD BASH
What is correct torque specifications for the cylinder head bolts?
Jan 5, 2021 at 11:21 AM
STEVE W.
  • 15,382 POSTS
Here are the specs for the head, cam sprocket and intake and exhaust manifolds..
Head - First pass to 44 Ft Lb. Then turn 95 degrees bolt pattern attached
Cam sprocket - 103 Ft Lb.
Intake manifold - Lower Center - First pass 62 inch pounds, Second pass 115 inch pounds= yellow
Intake manifold - Lower Corners - First pass 115 inch pounds, second pass to 18 Ft Lb= blue
Upper intake - 18 Ft. Lb.
Exhaust manifold - 12 Ft Lb
Jan 5, 2021 at 3:51 PM
