Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Murano
Brakes
Pads
Front
Torque specs brake caliper bracket and caliper bolts?
2020 NISSAN MURANO
87,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
BIGRON4570
MEMBER
I am replacing front and rear brake rotors and pads and I can't find the torque specs for the brake caliper bracket and caliper bolts
Apr 10, 2026 at 1:33 AM
Experienced Mechanic
Sure, here are the torque specs for both the front and rear brake calipers and caliper mounts.
Front caliper slide/caliper bolts: 34 lb-ft (45.6 Nm)
Front brake caliper mounting bracket bolts torque to 107 lb-ft
Rear brake caliper bolts slide-pin/caliper bolts: 32 lb-ft
Rear brake caliper mounting bracket bolts: 62 lb-ft
Hope this helps, let us know if you need anything else. Ken
Apr 11, 2026 at 1:07 AM
BIGRON4570
MEMBER
Thanks a lot I have been looking high and low for the answer. Very much appreciated
Apr 11, 2026 at 1:22 AM
You are welcome, please use 2CarPros anytime we are here to help.
Apr 11, 2026 at 1:36 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
