torque specs
270,746 MILES • 5.2L • V8 • 4WD • AUTOMATIC
MARKAARON
I need the recommended torque specs for rear differential ring gear bolt. Haynes repair manual only tells me what the differential cover bolts should be torqued too.
Feb 24, 2016 at 8:18 AM
HMAC300
  • 48,601 POSTS
70-90 ft. lbs except 8&1/4 ring gear which is 70 ft lbs.
Feb 24, 2016 at 10:13 PM
