Torque specifications needed for the driveshaft and transfer case?
69,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
ERNSTCLRK
What are the torque specs for the driveshaft and transfer case?
Nov 18, 2024 at 2:50 AM
  • 55,851 POSTS
Here are the driveshaft bolts and transfer case bolt torque specs:
Driveshaft Bolts:
Front Driveshaft to Transfer Case Bolts:
Torque Spec: 30 ft-lbs (40 Nm)
Rear Driveshaft to Rear Differential Bolts:
Center Support Bearing Bolts (if applicable):
Torque Spec: 18 ft-lbs (25 Nm)
Transfer Case Mounting Bolts to Transmission:
Torque Spec: 45 ft-lbs (61 Nm)
Transfer Case Drain/Fill Plug:
Torque Spec: 15 ft-lbs (20 Nm)
Let us know if you need anything else.
Nov 18, 2024 at 4:17 AM
