Need to know what the torque spec is on the inner and outer tie rods.
Dec 7, 2017 at 4:04 AM
STEVE W.
✓Experienced Mechanic
The only one I find in Nissans literature is for the outer tie rod nut and that is 25 ft. lbs. www.nicoclub.com/ has the FSM for that van online if you would like to dig through it.
As a general rule I torque the inner to around 60 ft.lb. if there is no real spec.
