What is the torque spec for the front wheel axle bolts?
200,009 MILES • 2.4L • 2WD • AUTOMATIC
MGSIL
  • 20 POSTS
Torque spec.
Mar 5, 2022 at 8:43 AM
  • 110,246 POSTS
I attached the torque specifications below for several things you may need. As far as the hub/axle nut, make sure you torque it to spec before placing weight on the wheel. Have a helper hold the brake on so you can do it.
Let me know if this helps.
See pic below.
Mar 5, 2022 at 1:41 PM
MGSIL
  • 20 POSTS
Thanks. Yes, it's exactly what i needed. But one more question what does 65 + 90° ft lbs on the strut to knuckle mean?
Mar 6, 2022 at 11:13 AM
  • 110,246 POSTS
First, you are very welcome. I'm glad it helped. As far as the 65 + 90, what that means is you torque the bolt to 65 ft/lbs. Once that is done, you need to turn the nut an additional 90 degrees (basically 1/4 of a turn).
Let me know if that helps.
Mar 6, 2022 at 11:50 AM
