I would appreciate if someone tell me the Torque spec of the differentials (front and back) bolts
Thank you
Dec 22, 2016 at 12:04 AM
RYAN L
✓Experienced Mechanic
Hello! The front differential cover bolt torque spec is 17 ft lbs. and the rear is 30 ft lbs. Make sure to bolt them on in a criss-cross pattern. Thank you so much for using 2CarPros! If you have anymore questions do not hesitate to ask!
