Torque Specification
102,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ZEMORZEMOR
  • 486 POSTS
I would appreciate if someone tell me the Torque spec of the differentials (front and back) bolts
Thank you
Dec 22, 2016 at 12:04 AM
RYAN L
  • 272 POSTS
Hello! The front differential cover bolt torque spec is 17 ft lbs. and the rear is 30 ft lbs. Make sure to bolt them on in a criss-cross pattern. Thank you so much for using 2CarPros! If you have anymore questions do not hesitate to ask!
Dec 22, 2016 at 7:06 AM
