Need torque settings and sequence of tighten nuts for install of exhaust manifold and oil cooler part.
Sep 15, 2024 at 7:47 AM
✓Experienced Mechanic
Sure, here are the instructions and the torque specs on how to replace and tighten the exhaust manifold. Be sure to clean the gasket surface thoroughly and I would use a little RTV to help seal the gasket. Check out the images (below). Let us know if you need anything else.
