Torque pattern
200 MILES • 3.7L • 6 CYL • 4WD • MANUAL
PAPAJOSEPH..
  • 7 POSTS
Replace rod bearing need torque pattern please.
Aug 24, 2018 at 11:51 PM
Good morning.
The specs are below for your rod bearings Let me know if you need any other specs.
Tightening Specifications
Connecting Rod Cap Bolts .................... 27 Nm (20 ft. lbs.) PLUS 90 degree turn
Dimensional Specifications
Bearing Clearance .................... 0.010 - 0.048 mm (0.0004 - 0.0019 in.)
Side Clearance .................... 0.10 - 0.35 mm (0.004 - 0.0138 in.)
Piston Pin Clearance .................... 0.015 - 0.028 mm (0.0006 - 0.0011 in.)
Bearing Bore Out of Round .................... 0.004 mm (0.0002 in.)
Total Weight (Less Bearing) .................... 612 grams (21.588 ounces)
Cheers, Roy
Aug 25, 2018 at 12:35 AM
PAPAJOSEPH..
  • 7 POSTS
I have that I need to know the torque pattern which pope start with and which way to go.
Aug 25, 2018 at 1:10 AM
Snug up each cap bolt and then start with the one on the driver's side.
Aug 25, 2018 at 8:03 AM
PAPAJOSEPH..
  • 7 POSTS
I need the torque specs for the engine.
Aug 25, 2018 at 8:29 AM (Merged)
PAPAJOSEPH..
  • 7 POSTS
That works. Appreciate the help Bud the long haul, but I am finished. Appreciate the help.
Aug 25, 2018 at 9:07 AM
You are welcome.
Glad to help.
Aug 25, 2018 at 9:09 AM
PAPAJOSEPH..
  • 7 POSTS
Changed rod bearing and still has a bad knocking. Any ideas?
Aug 25, 2018 at 12:07 PM
What was the bearing crush when you installed it? Did you use plastic gauge to measure the clearance?
Was the crank damaged? Does it have any grooves or scores?
Aug 25, 2018 at 12:21 PM
PAPAJOSEPH..
  • 7 POSTS
Yes, I checked all that and the crane and everything look good. It sounds like it is in the upper part of the motor this time.
Aug 25, 2018 at 12:25 PM
The upper end is a totally different noise than a rod.
To confirm it is a rod bearing, short down the cylinders one at a time. If the noise gets less intensive or goes away it is a rod bearing.
Aug 25, 2018 at 12:29 PM
PAPAJOSEPH..
  • 7 POSTS
Okay, I appreciate it bud.
Aug 25, 2018 at 12:31 PM
No problem. Glad to help.
Aug 25, 2018 at 12:35 PM
