One of the solenoid bolts is stripped and I cannot remove the solenoid
225,000 MILES • 3.0L • 6 CYL • AUTOMATIC
DAVID CHANDLER FARR
  • 41 POSTS
The solenoid I’m referring to is under the upper radiator hoses down near engine kind of hard to get at, how can I get this solenoid out and how can I force reset the check engine without a scanner?
Oct 15, 2021 at 6:03 AM
  • 110,248 POSTS
Hi, David.
I need you to take a picture of the component you are referring to. There really aren't any solenoids where you mentioned.
Take a look at the pic below. Do you see what you are referring to or can you tell me the location? Also, can you tell me what diagnostic trouble code was found?
See pic below.
Oct 15, 2021 at 1:13 PM
DAVID CHANDLER FARR
  • 41 POSTS
I have uploaded the codes for you.
Oct 15, 2021 at 2:50 PM
  • 110,248 POSTS
The codes are related mostly to the torque converter clutch solenoid. Take a look at the pic below and let me know if that is the component you are referring to.
If that, is it, what is stropped? Is it where the wrench goes on it or are the threads stripped causing the bolt to just turn and not come out?
If it is where the wrench attaches, use a bolt extractor. Basically, it is similar to a socket, but it's designed to cut into the stripped bolt so it can be removed. I attached a pic of what they look like.
As far as the reset, you can disconnect the battery terminals (negative first) and tie the two cables together with a zip tie. Allow it to sit that way for approximately 10 minutes. That will drain any power from capacitors. That should reset it. If it doesn't, it will turn itself off after a few trips where there isn't an issue.
When reconnecting the battery, start with the positive and then connect the negative.
Let me know if this helps.
Oct 16, 2021 at 2:56 PM
FARR2007
  • 244 POSTS
Yes, the solenoid I can’t get out looks like that there are 2 side by side.
Oct 16, 2021 at 7:42 PM
FARR2007
  • 244 POSTS
So how do I fix this?
Oct 16, 2021 at 11:20 PM
FARR2007
  • 244 POSTS
Where is the torque solenoids?
Oct 17, 2021 at 3:32 AM
  • 110,248 POSTS
The pic above is the TCC solenoid. As far as the bolt, is it the head of the bolt that is bad or the threads? If it's the bolt head, see if you can get your hands on a set of the extractors like I attached. Oftentimes, a parts store will lend them to you.
Then, find the size that fits snug over the stripped bolt head, and try loosening it with that on the bolt. They are made to cut into the bolt in the reverse direction so you can remove the bolt.
I attached the directions below for replacement. As far as torque, the manual isn't supplying them. I would think 7 - 10 ft pounds would be good.
Oct 17, 2021 at 1:41 PM
FARR2007
  • 244 POSTS
So, I drained the fluid again and there was like metal shaving on the magnet bolt and covered in grayish grease also without the extraction tool. how can i remove the solenoid?
Oct 18, 2021 at 4:36 AM
  • 110,248 POSTS
Without the tool, if the hex head is stripped, the best you can try is to use something like vice grips, or tap on a smaller socket, or anything that will grab that bolt.
Oct 18, 2021 at 10:40 AM
FARR2007
  • 244 POSTS
What about the metal shavings and grey greasy stuff on the drain bolt?
Oct 19, 2021 at 7:33 AM
  • 110,248 POSTS
Is it possible for you to take a couple of pics and upload them for me to see? That would make things much easier for me to follow.
Oct 19, 2021 at 11:33 AM
FARR2007
  • 244 POSTS
It looks like a previous owner welded the solenoid bolt to the transmission and I need to get the dang bolt out, what can I do?
Oct 22, 2021 at 4:48 AM
  • 110,248 POSTS
Wow! That isn't good. Can you take a pic and upload it for me to see it? That will help me come up with a few ideas.
Often times when I have an issue with a bolt, I will take an air Dremel and with a burr and slowly remove the area that is bad. In this case, the weld.
I need to see exactly what you are dealing with to be sure it would work.
Oct 22, 2021 at 12:58 PM
FARR2007
  • 244 POSTS
Here are the best pics I could get:
Oct 22, 2021 at 1:34 PM
FARR2007
  • 244 POSTS
I hope that helps!
Oct 22, 2021 at 1:52 PM
  • 110,248 POSTS
It does help. I don't see anything that appears welded. Were you able to try one of the bolt extractors I mentioned above? I feel that would remove the bolt for you. Simply get one that is slightly tight on the bolt, tap it on lightly, and then turn it to remove. It should bite into the bolt. There is enough left of it.
Oct 22, 2021 at 2:01 PM
FARR2007
  • 244 POSTS
See the problem is there really isn’t much space to tap anything onto it and I would have done so with a smaller socket if that were possible.
Oct 22, 2021 at 2:14 PM
  • 110,248 POSTS
If you place the socket on an extension, can you get it to a point that it's more accessible? The nice thing about the extractor I mentioned is even if you can't tap it gently into place, most times the pressure of pushing on it with your fingers will cause it to grab.
Oct 22, 2021 at 3:14 PM
FARR2007
  • 244 POSTS
Sorry to inform you the bolt extractor set failed and would not budge this bolt. I don't know what else to do!
Oct 23, 2021 at 7:32 AM
  • 110,248 POSTS
Since the space is limited, I'm not sure how I would handle it. Heat could help, but I don't like heating aluminum, but it can be done carefully. We can't cut it because then the threaded part will need drilled out and likely rethreaded.
At this point, I feel heating it may be the only choice. Are you able to heat the bolt with a torch? If so, heat the head of the bolt. In this case, the aluminum it's attached to will draw in the heat. Heat the bolt itself by keeping the flame about 2 to 3 inches away from the bolt head. Try to avoid directing the flame right at the aluminum. Focus it on the bolt head.
Once the bolt gets hot, allow it to cool to room temperature. See if it will come out then. If it doesn't then try heating it again. Eventually, the expansion and contraction of the different metals should break free from corrosion.
I wish I had an easier way to do it, but you have tried all the traditional ways.
I hope this helps.
Oct 23, 2021 at 12:47 PM
FARR2007
  • 244 POSTS
Joe, what is the correct part number for that solenoid?
Nov 1, 2021 at 7:50 AM
  • 110,248 POSTS
According to my repair manuals, it appears to be Honda part number 28500P6H003. Please confirm that when making a purchase.
Let me know if that helps.
Nov 1, 2021 at 2:05 PM
FARR2007
  • 244 POSTS
In this picture the housing the radiator hose goes to which in the picture is above the solenoid hole, my question is it possible to get more room to drill out the broken bolt with extractor by removing the metal pipe?
Nov 1, 2021 at 5:56 PM
  • 110,248 POSTS
Have you removed the hoses? And yes, anything you can get moved will help.
Nov 2, 2021 at 9:56 AM
FARR2007
  • 244 POSTS
Do you think I need a new solenoid?
Nov 2, 2021 at 9:58 AM
  • 110,248 POSTS
In your first post, you mentioned how to reset/clear the code. Was there a diagnostic trouble code related to this sensor? If so, I would replace it. If not, let me know what the code was so I can better direct you.
Nov 2, 2021 at 11:43 AM
FARR2007
  • 244 POSTS
Here’s code.
Nov 2, 2021 at 11:54 AM
  • 110,248 POSTS
Based on that code, I suggest replacing it. Chances are that is what set the code.
Let me know if I can help in any way.
Nov 2, 2021 at 12:50 PM
FARR2007
  • 244 POSTS
There are 2 sensors right next to each other, do both need replacing?
Nov 3, 2021 at 6:54 AM
  • 110,248 POSTS
Since the code is specific to the TCC solenoid, that is the only one I would replace.
Nov 3, 2021 at 10:31 AM
FARR2007
  • 244 POSTS
So, I replaced the torque converter solenoid and still doesn’t seem to want to move, it has a whiny noise near transmission, I am stumped what can be done.
Nov 18, 2021 at 12:12 PM
  • 110,248 POSTS
Is the noise loud enough for you to record and upload for me to hear?
Nov 18, 2021 at 12:40 PM
FARR2007
  • 244 POSTS
Well, basically sounds like low power steering same sound but it does at times go quiet I am so frustrated and can’t figure this dang car out.
Nov 18, 2021 at 1:48 PM
  • 110,248 POSTS
Is the transmission fluid clean and full as well as the power steering fluid? Also, can you pinpoint approximately where the sound is coming from?
Nov 19, 2021 at 12:15 PM
