Torque converter clutch solenoid
170,000 MILES • AUTOMATIC
KELLY BURTON
I got the code indicating the TCC. Transmission has been missing. I need to know the approximate cost to expect to replacing the part. To know if it is worth it.
Aug 7, 2017 at 6:01 AM
SATURNTECH9
  • 30,869 POSTS
I need the exact code number not code description it is a P followed by a four digit number.
Aug 7, 2017 at 9:42 AM
KELLY BURTON
The code came up PO 741/742. The part is only $35.00 but it is the labor cost that I am interested in. Thanks!
Aug 7, 2017 at 9:46 AM
SATURNTECH9
  • 30,869 POSTS
I just noticed you did not list if you have a four cylinder or a six cylinder engine? Also, who diagnosed the problem? Did someone say to replace the TCC solenoid?
Aug 7, 2017 at 2:12 PM
KELLY BURTON
It is a 2.2 engine. I took it to a auto parts store who diagnosed it and gave me the P codes.
Aug 8, 2017 at 12:15 AM
SATURNTECH9
  • 30,869 POSTS
So i am guessing that there guessing that they said it is a bad torque converter solenoid? That would only be a guess on there part. Most likely that is what it would it would be. but it would still have to be diagnosed as the actual problem. Also would have to make sure there was not excessive metals etc., in your transmission pan as well. It is 6.5 hours labor to replace your torque converter solenoid plus parts. That is times what ever the shop is charging for per hour for labor.
Aug 8, 2017 at 2:08 AM
KELLY BURTON
Yeah. That is about what I figured. So far I am getting estimates of $700.00 without even looking at it. Car is only worth a few hundred dollars more. I appreciate your help!
Aug 8, 2017 at 2:16 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome that's what we're here please tell all your friends about us
Aug 9, 2017 at 6:26 AM
