torque converter clutch solenoid
138,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
DANNY TANNER
car purrs like a kitten until i put it in gear, then it drops dead replace it in park are neutral and starts right up.
Aug 14, 2016 at 12:39 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it. also clean throttle plate on both sides and iac hole with choke cleaner.
Aug 15, 2016 at 12:13 AM
HMAC300
  • 48,601 POSTS
it may not be torque converter clutch solenoid causing problem. check engine light would be on as well.
Aug 15, 2016 at 12:14 AM
DANNY TANNER
Got code 13 says no crank angle. But I replaced distributor and timing belt. All OME parts.
Aug 15, 2016 at 1:45 AM
HMAC300
  • 48,601 POSTS
check for a cracked distributor or rotor cap and connections at ECM then follow checks on chart. that code means there is no rpm signal so it may be a bad ECM.
Aug 15, 2016 at 2:33 AM
DANNY TANNER
Okay, l will do that, and get back to you! Thanks for all the information. Man, I am glad fellows like all of you are willing to help guys like me! I will be in touch. Thanks again!
Aug 15, 2016 at 4:28 AM
  • 55,781 POSTS
No Problem!, we are here to help, please use 2CarPros anytime
Best, Ken
Aug 19, 2016 at 12:07 PM
