torque sheet to rebuild my motor?
180,000 MILES
MWOODEN89
Having issues finding a torque sheet to rebuild my motor?
Oct 4, 2024 at 3:25 PM
  • 55,676 POSTS
Sure, here is the torque specs when rebuilding your engine. Also, have you seen this video series? It can help you.
https://www.youtube.com/watch?v=QuNLrE3rrb8&list=PLe3kz1i_LrtW1Jw7wWI-3jSsaml8EjQVb&pp=iAQB
Common Torque Specifications for 2007 Ford F-150 (5.4L V8)
Cylinder Head Bolts:
First pass: 30 lb-ft (40 Nm)
Second pass: Tighten an additional 90 degrees
Final pass: Tighten an additional 90 degrees
Main Bearing Bolts:
Step 1: 35 lb-ft (47 Nm)
Step 2: 60 lb-ft (82 Nm)
Connecting Rod Bolts:
30 lb-ft (40 Nm)
Crankshaft Pulley Bolt:
66 lb-ft (90 Nm) plus an additional 90 degrees
Camshaft Caps:
89 inch-lbs (10 Nm)
Intake Manifold Bolts:
89 inch-lbs (10 Nm)
Exhaust Manifold Bolts:
18 lb-ft (25 Nm)
Oil Pan Bolts:
10 lb-ft (14 Nm)
Flywheel Bolts:
44 lb-ft (60 Nm) then 90 degrees
Let us know if you need anything else.
Oct 5, 2024 at 6:08 AM
